https://help.tallysolutions.com/docs/te9rel50/Banking/Post-dated_Received.htm
Post-dated Received
Drill down from the Amount and Count values displayed under the Received column. The Post-dated Received report appears as shown:
The report displays information as follows:
  • Date: This column displays the date provided in the voucher while recording the post-dated transaction in Tally.ERP 9.
  • Particulars: This column displays the name of the party ledger that has been used to record the transaction.
  • Bank: This column displays the name of the bank whose cheque has been received.
  • Inst. No.: This column displays the instrument number entered in the Bank Allocations screen while recording the transaction.
  • Inst. Date: This column displays the instrument date entered in the Bank Allocations screen while recording the transaction. That is, the date provided on the face of the cheque.
  • Issuing Bank: This column displays the name of the payer’s bank.
  • Status: This column indicates if the current status of the cheque. There are four types of status for a cheque:
  • Regularized: if the date of the cheque is equal or more than the Date of Last Entry indicated in the Gateway of Tally.
  • Pending: when the cheque date is lesser than the Date of Last Entry.
  • Reconciled: if the cheque is reconciled.
  • Unlinked: if the cheque is deposited in a notional bank.
  • Amount: This column displays the value of the post-dated cheque received.
The F12: Configure options available for this report are as shown:
  • Show received from/payment to: Set this option to Yes to view the name of the payer. This is the name provided in the Received From field of the Bank Allocations screen.
  • Show PDC Notes: Set this option to Yes to view the remarks provided using the K: Enter Notes button.
  • Show issue/receipt date: Set this option to Yes to view the date on which the cheque was received. This is the date provided in PDC Receipt Date field of the Bank Allocations screen.
