https://help.tallysolutions.com/docs/te9rel50/Creating_Masters/Accounts_Info/Voucher_Class_for_Journals.htm
Voucher Class for Journals
Voucher Classes in Journals is used to handle Forex Gain Loss Adjustments for companies having Multi-Currency Accounts. You would create a 'class' in the normal way (Accounts Info > Voucher Types > Alter > Journal). Having selected the class during Voucher Entry, you will find only those Ledger Accounts appearing which have a Gain/Loss to be adjusted as of the date of voucher and auto-calculation of these amounts.
