https://help.tallysolutions.com/docs/te9rel50/Control_Centre/Surrender_License_from_Control_Centre.htm
Surrender License from Control Centre
You can surrender the license from the Control Centre under any one of the following circumstances.
  • The computer with Tally.ERP 9 installed has crashed
  • Formatted the Hard Disk without surrendering the license
  • Surrender license offline.
To surrender the license from the Control Centre follow the steps shown:
Go to Gateway of Tally > K: Control Centre
  • Login to the Control Centre using the Email ID of the Account/Site Administrator
The Control Centre screen appears
  • Select My Tally.NET Account
The My Tally.NET Accounts screen appears
  • Select the required Account ID
The Control Centre screen for the select Account ID appears
  • Select Licensing & Configuration
  • Tab down to the Status column and set the status to Surrendered  for the respective Site ID
The Warning message appears as shown:
  • Press Enter to Surrender the license
On successfully surrendering the license, access the required Tally.ERP 9 folder and delete the license file (Tally.lic). You can now proceed to reactivate the license for the respective site.
