https://help.tallysolutions.com/docs/te9rel50/Tax_International/Bangladesh/Supplier_Ledger.htm
Creating a Supplier Ledger
To create a Supplier ledger:
  1. Enter the Name of the Supplier ledger.
  2. Select Sundry Creditors as the group name in the Under field
  3. Set Maintain balances bill-by-bill to Yes
  4. Enter the Default Credit Period if any
  5. Enter the Mailing Details and Tax Information of the supplier
  6. Enter the 11 digit TIN number of the supplier
  7. Enter the Opening Balance, if any
  1. Press Y or Enter to accept and save the screen.
