44AB Audit is enhanced to not list clause 17h Amounts inadmissible u/s 40A(3) if there are no eligible vouchers: The 44AB Audit is enhanced to not list clause 17h Amounts inadmissible u/s 40A(3) in the Audit Type column of clause 17, when there are no vouchers eligible for that particular clause.
A provision is made in clause 17h of 44AB to audit cash purchases: Provision is made to audit all cash purchases as cash payments have to reflect in Clause 17h off 44AB Audit.
Now, skipped ledger accounts will be shown by default, and the same can be removed using the button.
Now, the voucher count in Clause 17h and drill down screen will not differ when viewed Range-wise.
Now, disabling verification of vouchers will not disable clause 17 (a-m).
In 44AB Tax Audit report, all drill down screens under different clauses will now have the same reporting period as the dashboard.
Now, Date of Acquisition field will only display the respective date entered in printouts and exported files.
Audited column of 17 Amounts debited to P&L a/c in 44AB Audit dashboard was not getting updated when transactions under clause 17(f) and 17(m) were marked as audited, resolved: Now, when transactions under clause 17(f) and 17(m) are marked as audited, the Audited column of 17 Amounts debited to P&L a/c in 44AB Audit dashboard is updated.
In 44AB Audit, vouchers marked for external clarification under clause 17(a-m) and Verification of Vouchers appeared in the List of Clarifications report even after the clauses were disabled, resolved: Now, if Verification of Vouchers is disabled, vouchers under clause 17(a-m), which are marked for clarification, will not be listed in the Clarifications list.
Ledger Vouchers report under clause 24 (a) of 44AB Audit was displaying vouchers not pertaining to the selected period, resolved: Now the vouchers pertaining to the period selected under F2: Period are displayed in the Ledger Vouchers report.
The help button H: Help was not working from the print preview screen, resolved: Now, pressing Alt+H or clicking H: Help from the print preview screen opens the help.
Release 5.0 |
'Release 5.0 bug fixes Tax Audit' has been shared with
