https://help.tallysolutions.com/docs/te9rel50/Data_Management/DM_Backup.htm
Backup
Data on the computer is vulnerable to different types of threats and any data lost cannot be recovered. Hence, there is a need to store data at a different location by taking a backup.
It is advisable to take data backup at frequent intervals as per the policies laid down by the organization and also ensure that the data backup is secured logically and physically.
To know more about taking a backup, click on the following link:
