https://help.tallysolutions.com/docs/te9rel50/Data_Management/DM_Alter_TallyVault_Cmp.htm
Altering TallyVault for a Company
To alter the TallyVault for an existing company execute the following steps:
Go to Gateway of Tally > Press F3: Company Info > Change TallyVault
Repeat the entire process as described in Enabling TallyVault in Existing Company. The Change TallyVault screen has an additional field Current Password; enter the present password in the Current Password field. Enter the new password in the New Password field and repeat the same password in the Repeat New Password field.
1. Accept to Change the TallyVault password.
2. Tally.ERP 9 prompts the user with a message Created New Company
