https://help.tallysolutions.com/docs/te9rel50/Tax_International/Kenya_VAT/vat_ledger.htm
Input VAT Ledger
Input VAT ledgers are required to account for input credit on Goods/Services purchased.
Input VAT Ledger
To create an Input VAT Ledger,
  • Enter the Name of the Input VAT ledger.
  • Select Duties & Taxes as the group name in the Under field.
  • Select VAT from the Type of Duty/Tax list in the field Type of Duty/Tax.
  • In VAT Sub Type field select the appropriate VAT Sub Type - Input VAT (to account for  input credit on  Purchases. Depending on the VAT Sub Type selected, Tally.ERP 9 will display the VAT/Tax Class for selection in VAT/Tax Class field. For Example, if Input VAT is selected as VAT Sub Type, application will display only the Input VAT Classifications for selection in VAT/ Tax Class field.
  • In VAT/Tax Class field select the required VAT/Tax Class from the VAT/TAX Class list.
  • The Percentage of Calculation and Method of Calculation is set as per the VAT/Tax Class selected.
  • Accept the input VAT ledger.
Note: It is recommended that Input VAT Ledgers be created with appropriate VAT classifications for different rates of VAT.
