https://help.tallysolutions.com/docs/te9rel50/Job_Work/JI_Stock_Ageing_Analysis.htm
 Stock Ageing Analysis
Stock Ageing Analysis report displays the details of period (i.e. for how long) the Principal manufacturers stock is lying with the Job worker.
To view the stock Ageing Analysis reports
Go to Gateway of Tally > Display > Job Work In Reports > Stock > Ageing Analysis
  • In Select Item screen select the stock group foe which the Ageing Analysis report to be viewed
The Stock Ageing Analysis report is displayed as shown
