https://help.tallysolutions.com/docs/te9rel50/Auditor_Edition/International_Audit/Identifying_related_Parties.htm
Identifying Related Parties
Those Ledgers which are marked by the User as Related Party will only appear in the Related Party Transactions report.
To identify/mark a Ledger as Related Party,
Go to Gateway of Tally > Analysis & Verification > Verify > Related Party Transactions
  • Click on Ctrl+F9: Master Config or press Ctrl+F9
  • Select Related Party and press Enter
  • Select the required Ledger(s) using Spacebar in the Related Party Configuration screen
  • Click on F5: Update or press F5 to view Related Party Details screen to mark the selected Ledger as Related Parties.
  • In Related Party Details screen
  • In Is Related Party field select Yes
  • In Relation Type field specify the relation type
  • Press Enter to save the Related Party Configurations.
Note: Follow the same steps to unmark a Party which is wrongly identified as Related Party.
Ctrl+W: Wkg Paper
To view the Working Paper during analysis, click on Ctrl+W: Wkg Paper or press Ctrl+W keys. The details displayed in Working Paper will be relevant to report from where it is triggered. This report displays the details of Configuration of Periodic Ledgers.
