https://help.tallysolutions.com/docs/te9rel50/Advanced_Features/Advanced_Accounting_Features/Enabling_Multi_Address.htm
Enabling Multi Address
To enable Multi Address in Tally.ERP 9:
  • Go to Gateway of Tally > F11: Accounting Features.
  • Under Other Features set Maintain Multiple Mailing Details for Company & Ledgers to Yes.
To add multiple mailing details for your company:
  • Set the option Set/Alter Company Mailing Details to Yes as shown:
  • Press Enter.
Note: Primary under Address Type contains the Mailing Details provided in the Company Creation screen. You may also alter the primary mailing details from this screen.
  • The Mailing Details screen appears.
  • Enter the Mailing Name, Address, PIN Code, etc. in the respective fields provided.
The filled Mailing Details screen appears as shown:
  • Press Enter,  the Address Type screen appears.
  • Similarly, type another Address Type name to create the Mailing Details.
  • Press Enter.
  • The Company Operations Alteration (F11 Features > Accounting Features) screen appears  as shown:
  • Accept to save the settings.
