https://help.tallysolutions.com/docs/te9rel50/Release_Notes/Technical_Features/Export___Import.htm
Export/Import
86771
73739
51168
82450, 88308, 67476
62707
  • When Ledgers of All Accounts were exported to Excel, the exported file was appearing incorrectly aligned, resolved: When Ledgers of All Accounts were exported to Excel with the option Show Billwise Details also set to Yes, the columns in the exported file were not aligned correctly.
Go to Gateway of Tally > Multi Account Printing > Accounts Books > Ledger > All Accounts and click E: Export to export the file to Excel.
Now, the Vch Type, Vch No., Debit, and Credit column are aligned correctly.
49203
52827
67514
69454
61297
47577
47942
  • When exporting Day Book to .pdf or .jpeg format, columns were overlapping, resolved: Now, exporting of reports such as Day Book in .pdf or .jpeg formats will not affect the formatting of the out file and there will be no overlap of columns.
42330
  • Columns were not aligned properly when Day Book was exported to .pdf or .jpeg format, resolved: When the Day Book was exported to .pdf or .jpeg formats the output file was not aligned properly. This occurred when the option Show Narrations also and Show Entered/Altered By are set to Yes in the Export Report screen.
63531
56793
  • The issue of the Vertical Balance Sheet displaying inconsistent borders when exported in Excel format, resolved.
55945
50068
79272
60797
69422
43043
  • The option Export for Pivot Table has been provided in the Exporting Summary screen: You can now get despatch details while exporting Sales Register in Excel (Spreadsheet) format.
78934
54418
98119
52145
  • Unable to copy item from one company to another by changing the company master in the item alteration screen, resolved: When an item master is opened in alteration mode and saved in another company by switching the company master using F3: Company button, an error “Stock Item ‘ ‘ already exists!” was being displayed. This occurred when standard rates was enabled and configured for the item.
See also:
Release 5.0
