https://help.tallysolutions.com/docs/te9rel50/Payroll/ESI_Process.htm
ESI Process
Like provident fund, ESI amounts are calculated separately. However, you need to pay the amount using a single payment voucher.
To process the Employer ESI Contribution
  1. Go to Gateway of Tally > Payroll Vouchers > Ctrl + F4: Payroll.
  2. Press F2 to change the Voucher Date.
  3. Click A: Payroll Auto Fill.
  4. Select the required process in Process for field.
  5. Enter the From and To date.
  6. Select the appropriate Employee Category.
  7. Select the Employee/Group from the List of Employees/Group.
  8. Select the appropriate Payroll Ledger from the List of Ledger Accounts.
  1. Press Enter to go to Payroll Voucher Creation screen.
  1. Press Enter to save.
