https://help.tallysolutions.com/docs/te9rel50/Control_Centre/Change_Password_Control_Centre.htm
Change Password
You can use this option to change password at your convenience. As per the best practices available, it is recommended to change the password frequently in order to avoid unauthorised access to business information.
To change the Password follow the steps shown:
In the Control Centre screen
  • Press Alt + P or click P:Change Password button.
The Change Password screen appears with the Username
  • Enter the current password in Old Password field.
  • Enter the new password in New Password field.
  • Repeat the new password in Repeat field for the purpose of confirmation. The Password Strength indicator displays the strength of the new password.
Note: To understand the conditions that determine a Password's strength, click Password Strength Indicator.
  • Accept to change the password.
