https://help.tallysolutions.com/docs/te9rel50/Tax_India/Excise_Importer/Defining_Tariff_Rates_at_company_level.htm
Defining Tariff Rates at Company Level
ABC company is an electronics company dealing with the import of laptops. They import only 12 inch Windows 8 laptops. Let us see how excise tariff can be defined and applied in a scenario like this.
To define tariff  rate at the company level
  1. Go to Gateway of Tally > F11: Features > F3: Statutory and Taxation.
  2. Set the option Enable Excise to Yes.
  3. Set the option Set/alter excise tariff details to Yes in the Excise Details screen.
The Excise Registration Details screen appears as shown below:
  1. Enter the excise details and define the duty rate.
The Excise Tariff Details screen appears as shown below:
  • Press Enter to save.
  1. Press Enter to save the Excise Registration details.
Creating Duty Ledger
  • Create a duty ledger with the Type of Duty as CENVAT and the Duty Head as Countervailing Duty.
Using the defined duty rate in a transaction
On selecting the duty ledger created in a transaction, the duty rate is calculated.
