https://help.tallysolutions.com/docs/te9rel50/Job_Work/Job_Work_In_TallyERP_9.htm
Job Work in Tally.ERP 9
Tally.ERP 9’s simple yet powerful Job Work feature enables you to record transactions related to Job Work with ease. The Job work functionality in Tally.ERP 9 has the following features:
  • Simple and user-friendly
  • Quick and easy to set up and use
  • Job Work Out Process
  • Record Job Work Out Order by capturing the details of Components to be issued and Finished Goods /Scrap to be issued
  • Account the Receipt of Components towards a Job order or directly record the Material receipt by creating the Job Order.
  • Flexibility to account the Receipt of Finished goods without raising Job Work Out Order and Material In voucher
  • Track cost against the Job Work Out Orders
  • Job Work In Process
  • Record Job Work In Order by capturing the details of Components to be received and Finished Goods /Scrap to be delivered
  • Flexibility to account the delivery of Finished goods without raising Job Work Out Order and Material In voucher
  • Track the Own Consumption of Goods against the Job Orders and Bill the same on the Principal manufacturer
  • Generate Annexure II for Removal of Goods for Job Work
  • Maintain and Generate Annexure IV (by Principal Manufacturer - if excise applicable)
  • Maintain & generate Annexure V (By Job Worker - if excise applicable)
  • Reports
  • Generate Order Outstandings report for Orders & Components
  • Generate Job Work Registers such as
    • Job Work Out Order/ Job Work In Order
    • Material Out Registers
    • Material In Registers
    • Material movement Register
  • Provision to view the details of Stock lying with the Job worker and ageing of the stock
  • Provision to generate the report to analyse the variance in issue of components and receipt of finished goods and vice versa.
