https://help.tallysolutions.com/docs/te9rel50/Tax_India/VAT/Karnataka/Pur_Annx_Kar.htm
Purchase Annexures
On this page:
Generating Purchase Annexures
Local Purchases
Local Purchase Returns
Interstate Purchases
Interstate Purchase Returns
To generate the aforementioned annexures
  1. Go to Gateway of Tally > Display > Statutory Reports > VAT > Form VAT 100
  2. Select Annexure Ready and press Enter or click V: VAT Annexure button.
In the e-VAT Annexures screen,
  1. Select any of the annexures and press Enter. The transactions forming part of the selected annexure is displayed.
  2. Press P: Print button to generate the print preview of the selected annexure.
Local Purchases
Pre-requisites to capture values in Local Purchases Annexure
Party Ledger
Following details should be defined in the party ledger selected in the purchase invoice.
  • VAT TIN should be of 11 digits with '29' as the first two digits
  • Type of Dealer set to Regular, Unregistered or Composition
Nature of Transaction
In Local Purchases annexure, the values of purchase recorded using the following Nature of Transactions are displayed:
  • Purchase Taxable
  • Purchase - Works Contract
  • Purchase Exempt
  • Purchase From Composition Dealer
  • Purchase From Unregistered Dealer
  • Purchase Others
  • Consignment Transfer Inward
VAT Rates
To display transaction details of purchases recorded using the aforementioned taxable Nature of Transactionifications, the VAT rates have to be defined in the,
  • Stock item master
  • Purchase ledger, if common ledger is not being used
The tax rates considered in this annexure for purchases made from registered and unregistered dealers are, 1%, 2%, 4%, 5%, 5.5%, 12.5%, 13.5%, 14%, 14.5%, 15%, 15.65%, 17%, 20%, 25% and 28%.
The description on each column of this annexure is given below:
Seller TIN
The VAT TIN of 11 digits with 29 as the first two digits predefined in the party master or entered in the Party Details screen of purchase invoice is displayed here.
Name of Seller
The name of the party or cash ledger selected in the Purchase invoice is displayed here.
Invoice Number
The invoice number entered in the Supplier Invoice No. field of purchase invoice is displayed here.
Invoice Date (DD/MM/YYYY)
The invoice date entered in the Date field adjacent to Supplier Invoice No. field of purchase invoice is displayed in DD/MM/YYYY format.
Net Value
The assessable value of purchases is displayed here.
Tax Value
The input VAT paid on taxable purchases is displayed here.
Other Charges
The value entered for separately charged expenses (ledger grouped under direct/indirect expenses with the option Use for Assessable Value Calculation set to No) is displayed here.
Total Value
The transaction or invoice value is displayed here.
Pre-requisites to capture values in Local Purchase Returns Annexure
Party Ledger
In Local Purchase Returns annexure, the values of Debit Notes recorded using the following Nature of Transaction are displayed:
  • Purchase Taxable
  • Purchase Exempt
  • Purchase Others
VAT Rates
To display transaction details of purchase returns recorded in Debit Note using the aforementioned taxable Nature of Transactionifications, the VAT rates have to be defined in the,
  • Stock item master
The tax rates considered in this annexure for purchase returns made to registered and unregistered dealers are, 1%, 2%, 4%, 5%, 5.5%, 12.5%, 13.5%, 14%, 14.5%, 15%, 15.65%, 17%, 20%, 25% and 28%.
Debit Note No.
The voucher number of Debit Note is displayed here.
Debit Note Date (DD/MM/YYYY)
The voucher date of Debit Note is displayed in DD/MM/YYYY format.
Seller TIN
The VAT TIN of 11 digits with 29 as the first two digits predefined in the party master or entered in the Party Details screen of Debit Note is displayed here.
Name of Seller
The name of the party ledger selected in Debit Note is displayed here.
Net Value
The assessable value of Debit Note is displayed here.
Tax Value
The input VAT amount of Debit Note is displayed here.
Other Charges
Total Value
The transaction or Debit Note value is displayed here.
Original Invoice Number
The number entered in Original Invoice No. field of Debit Note is displayed here.
Original Invoice Date (DD/MM/YYYY)
The date entered in the Original Invoice field of Debit Note is displayed in DD/MM/YYYY format.
Pre-requisites to capture values in Interstate Purchases Annexure
Party Ledger
  • VAT TIN should be of 11 digits with the first two digits other than '29'
In Interstate Purchases annexure, the values of purchases recorded using the following Nature of Transactions are displayed:
  • Inter-State Purchases
  • Interstate Consignment Transfer Inward
  • Imports
  • Interstate Purchase - Against Form C
  • Interstate Purchase Deemed Export
  • Interstate Purchase - E1
  • Interstate Purchase - E2
  • Interstate Purchase - Taxable
VAT Rates
  • Stock item master
The tax rates considered in this annexure for interstate purchases made from dealers are, 1%, 2%, 4%, 5%, 5.5%, 12.5%, 13.5%, 14%, 14.5%, 15%, 15.65%, 17%, 20%, 25% and 28%.
Seller TIN
The VAT TIN of 11 digits with first two digits other than 29 predefined in the party master or entered in the Party Details screen of purchase invoice is displayed here.
Name of Seller
The name of the party ledger selected in the Purchase invoice is displayed here.
Invoice Number
Net Value
The assessable value of interstate purchases is captured here.
Tax Value
The CST paid on taxable interstate purchases is captured here.
Other Charges
Total Value (Net Value + Tax Charged + Other Charges)
Form Type
The declaration Form selected in Statutory Details screen (which appears on enabling the option Provide Statutory Details) of Purchase invoice is displayed here.
Main Commodity
The Main Commodity Code predefined for the stock item selected in the invoice is displayed here.
Sub Commodity Code
The Sub Commodity Code predefined for the stock item selected in the invoice is displayed here.
Quantity
The quantity entered for the stock item in the invoice is displayed here. If two or more stock items are selected in the invoice and the unit of measurement is different for each item, then, the quantity displayed will be of the item of high value.
For example, if an invoice is recorded with items details given below, the quantity will be captured as 100 Kgs in the annexure as the assessable value of Item A is higher than that of Item B.
  • 100 Kgs of Item A costs 10,000
  • 80 Lts of Item B costs 5,000
Purpose Type
The Purpose of Purchase selected in the Statutory Details screen (which appears on enabling the option Provide Statutory Details) is displayed here.
Pre-requisites to capture values in Interstate Purchase Returns Annexure
Party Ledger
Following details should be defined in the party ledger selected in the Debit Note.
In Interstate Purchase Returns annexure, the value of transactions recorded in Debit Note using the following Nature of Transactions are displayed:
  • Imports
VAT Rates
To display transaction details of interstate purchase returns recorded using the aforementioned taxable Nature of Transactionifications, the VAT rates have to be defined in the,
  • Stock item master
Debit Note No.
The voucher date of Debit Note is displayed here in DD/MM/YYYY format.
Seller TIN
The VAT TIN of 11 digits with first two digits other than 29 predefined in the party master or entered in the Party Details screen of Debit Note is displayed here.
Name of Seller
The name of the party ledger selected in the Debit Note is displayed here.
Net Value
Tax Value
The CST on Debit Note is displayed here.
Other Charges
The date entered in the Original Invoice field of Debit Note is displayed here in DD/MM/YYYY format.
