https://help.tallysolutions.com/docs/te9rel53/Voucher_Entry/Inventory_Vouchers/Predefined_Inventory_Vouchers_in_TallyERP.htm
Inventory Vouchers in Tally.ERP 9
Tally.ERP 9 comprises of the following predefined Vouchers, to suit different business requirements for recording various transactions. Tally also allows you to create user-defined Vouchers (Voucher Types) as per your requirements.
More:
Pre-defined Inventory Vouchers in Tally.ERP 9
