https://help.tallysolutions.com/docs/te9rel53/Release_5_3_1/Product_Improvements.htm
Release 5.3.1 - Product Improvements
Banking
●      Provision made to allow users to define the separator for date format in cheque printing configuration.
Excise
●      The issue of Tariff Name and HSN code not being migrated for stock items in excise for manufacturers, resolved: Tariff Name and HSN code of stock items were not migrated from 4.9x. when,
o      Tariff Classification was specified and
o      Duty Details were not specified.
TDS
●      Bill-wise amount was wrongly captured in journal voucher when TDS was deducted, resolved: In a journal voucher when TDS amount was deducted, and any ledger(s) having the option Is TDS Applicable? set as Undefined was debited or credited, the bill-wise amount was incorrect. When deducting TDS in a journal voucher, if any ledger(s) having the option Is TDS Applicable? set as Undefined was debited or credited, the bill-wise amount was captured incorrectly.
Technical Features
Cheque Printing
●      When a user in a multi-user environment entered the Cheque Printing screen, Tally.ERP 9 was being unresponsive for all the other users until the user exited the Cheque Printing screen, resolved.
TDL
●      HTTP header Content-Type specified through TDL report was being overridden by the default header value, resolved: During integration with a third party web service, the value of the HTTP header Content-Type (expected by the web service) specified in the request header through TDL report, was overridden by the default header value text/xml. As a result of this, all incoming requests from Tally.ERP 9 were rejected by the web service, and the error message unsupported media type was displayed.
VAT
Haryana
●      Provision is made to support the latest changes provided by the department in annexures LP3B and LS9A in Version: 0.2.1 on 20th Jan 2016: Now, in annexures LP3B provision is made to record freight charges, product value, tax value and total value. In annexure LS 9A, options in the Rate of Tax column are modified.
*States covered for enhanced VAT experience
