https://help.tallysolutions.com/docs/te9rel53/Tax_India/VAT/Puducherry/PY_Incr_Output_Tax.htm
Recording Increase in Output Tax (Puducherry)
To record journal voucher for increase of output tax
1.     Go to Gateway of Tally > Accounting Vouchers > F7: Journal.
2.     Click J: Stat Adjustment to enable the required options in the Stat Adjustment Details screen.
o      Select VAT as Type of duty/tax.
o      Select Increase of Output Tax as the Nature of adjustment.
o      Select the Other Adjustments in Additional Details field.
o      Press Enter to return to the voucher.
3.     Debit party ledger created under Sundry Debtors and enter the amount in Debit column.
4.     Credit the sales ledger and enter the amount in Credit column.
5.     Credit the VAT ledger grouped under Duties & Taxes.
6.     Press Enter to save.
