To record local purchase of items with multiple VAT rates
1. Go to Gateway of Tally > Accounting Vouchers > F9: Purchases.
2. Enter Supplier Invoice No. and Date.
3. Select the party ledger in Party's A/c Name option.
4. Select a common purchase ledger in which the option Is VAT/CST Applicable is set to Applicable, and Set/Alter VAT Details is disabled.
5. Select the required stock items whose VAT rates are specified either at the stock group or stock item level. Enter Quantity and Rate for each stock item.
6. Select the common VAT ledger.
Ledger must be grouped under Duties & Taxes in which the options:
o Type of Duty/Tax is set to VAT.
o Use for Purchase Tax is disabled.
o Percentage of Calculation is set to ‘0’.
7. Click A: Tax Analysis button to display the Tax Analysis screen.
8. Click F1: Detailed button to view the names of stock items.
The Tax Analysis screen appears as shown below:
9. Press Esc to return to purchase invoice.
10. Press Enter to save.
'Recording Taxable Purchases (Telangana)' has been shared with
