https://help.tallysolutions.com/docs/te9rel53/Tax_India/TDS/Expense_Ledger.htm
Creating Expenses Ledger (TDS)
To create an expense ledger
  1. Go to Gateway of Tally > Accounts Info. > Ledgers > Create
  2. Enter the Name.
  3. Select Indirect Expenses  as the group name in the Under field.
  4. Set Inventory values are affected to No.
  5. Set the option Is TDS Applicable to Applicable.
  6. Select the Nature of Payment from the List of Nature of Payments.
  1. Press Ctrl + A to save the details.
