https://help.tallysolutions.com/docs/te9rel53/Tax_India/Excise_Mfg/Excise_Godown.htm
Creating Excise Unit or Godown (Excise for Manufacturer)
To create godowns or excise units
  1. Go to Gateway of Tally > Inventory Info. > Godowns / Excise Units > Create.
  2. Enter the Name of the excise unit.
  3. Select the required godown to group the godown being created.
  4. Select the Excise Tax Unit from the List of Excise Tax Units displayed.
The completed Godown Creation screen appears as shown below:
  1. Press Enter to save.
