https://help.tallysolutions.com/docs/te9rel53/Tax_India/Excise_Mfg/Tax_Units.htm
Creating Tax Units (Excise for Manufacturer)
To create a tax unit
  1. Go to Gateway of Tally > Accounts Info. > Statutory Info.> Tax Unit > Create.
  2. Enter Tax Unit Name.
  3. Enter the Address, State, Pin Code, and Telephone.
  4. Select Excise in the field Registered for.
  5. Enable the option Set/Alter Excise details.
  6. Press Enter.
The completed Tax Unit Creation screen appears as shown below:
  1. Press Enter.
Click the links below for more configurations:
Enabling multiple excise units
Recording Importer Exporter Code (IEC)
Recording Large Taxpayer Unit details
Enabling as dealer of only 2% goods
Recording Export Details
Creating or modifying Rule 11 book
Recording Jurisdiction Details
