Importing Vouchers
https://help.tallysolutions.com/docs/te9rel53/Data_Management/DM_Import_Vch.htm
Import of Vouchers
You can import vouchers from one company to another in Tally. ERP 9. This could be due to any of the following:
●      Data corruption/loss
●      For migration into a later release
●      For data import from third party
To import vouchers
1.     Go to Gateway of Tally > Import Data > Vouchers to view the Import Data screen.
2.     Enter the name of the .xml file to be imported. The file should be present in the Tally.ERP 9 application folder.
The Import Data screen appears as shown below:
3.     Press Enter to import.
Note: To view the import log, open the file Tally.imp in the Tally.ERP 9 folder.
The imported data is now ready to be used.
