The VAT Form 231 report is designed to provide an overview of the statistics of transactions pertaining to a period. It displays the assessable value and tax amount of purchases and sales, payments made, and the amount of VAT payable/refundable. The report also displays the count of Included Transactions that form a part of VAT annexures. Transactions which have partial information, and require user intervention to provide the details are categorized as Uncertain Transactions. Drill-down reports till the last level of voucher entry are provided for each section of this report with complete information of vouchers categorized under it.
With the intuitive feature of exception handling provided in this report, the exceptions can be solved to generate the returns to be filed for a particular period. The report provides the facility to save the original returns. If any changes are made in transactions, the information can either be overwritten or saved as revised returns.
To view the Form VAT 231
Go to Gateway of Tally > Display > Statutory Reports > VAT > Form 231.
VAT Form 231 can be filed on time with the accurate information available in this report. It has three main sections:
'VAT Form 231 (Maharashtra)' has been shared with
