Defining Tax Rates at Company Level
https://help.tallysolutions.com/docs/te9rel53/Tax_India/VAT/Karnataka/Define_Tax_Cmp_Level.htm
On this page:
Defining Tax Rates
Creating Tax Ledger
The VAT rate defined at the company level will be automatically applied while recording sales and purchase transactions.
Defining Tax Rates
●      Go to Gateway of Tally > F11: Features > Statutory & Taxation.
●      Enable the option Set/alter VAT Details. The Company VAT Details screen appears as shown below:
To define a single VAT/CST rate at the company level
1.     Select the State.
Note: State is auto filled if you have selected the state during company creation.
2.     Enter the TIN.
3.     Press Enter to skip Inter-state Sales Tax Number.
4.     Enable Set/alter tax/rate details. The Tax/Rate Details screen appears as shown below:
5.     Enter the Tax rate, as required.
6.     Click F12: Configure to open the Configuration screen to enable CST.
7.     Press Enter to return to the Company VAT Details screen.
8.     Click F12: Configure to enter additional details if required.
9.     Press Ctrl+A to save.
Creating Tax Ledger
To create a common VAT ledger
1.     Go to Gateway of Tally > Accounts Info. > Ledgers > Create.
2.     Enter the Name of the VAT ledger.
3.     Select Duties & Taxes in the Under field.
4.     Select VAT as the Type of duty/tax.
5.     Set Use for Purchase Tax to No.
6.     Press Enter to skip Percentage of Calculation (eg 5).
7.     Press Enter to save.
Similarly, create a CST ledger under Duties & Taxes, by selecting CST as the Type of Duty/Tax.
