To create journal voucher for decreasing output tax in lieu TDS paid
2. Click J: Stat Adjustment to enable required options in Stat Payment Details screen.
In the Stat Adjustment Details screen,
o Select the option Decrease of Output Tax in the Nature of adjustment field.
o Select the option TDS Adjustments in the Additional Details field.
o Press Enter to save and return to voucher screen.
3. Debit the VAT ledger created under the group Duties & Taxes.
o Enter the Rate and Assessable Value in the VAT Details screen.
4. Enter the amount in Debit column.
5. Credit the ledger created under the group Current Assets.
6. Enter Narration, if required.
7. Press Enter to save.
'Recording Decrease in Output Tax (Delhi)' has been shared with
