https://help.tallysolutions.com/docs/te9rel53/Creating_Masters/Inventory_Info/Inventory_Configurations_Features_F11_F12.htm
Features and Configuration Options (F11, F12) - Inventory
Configuration of Inventory
By using F12:Configure, you can enable the required settings of Inventory Masters.
By default, the settings pertaining to Inventory Masters are set to No.  If you set them to Yes, the features will be enabled. Typically, they are additional fields that appear during Masters creation which enable you to obtain more information and detailed analyses. Refer Accts/Inv Info. Configuration for more details.
Note: If you press F12 anywhere in the Menu, it will take you to the configuration menu.
Features of Inventory
By using F11:Features, you can enable the various settings under inventory features which determine the information to be entered during transaction entries.
Refer Inventory Features for more details.
