To export masters
1. Go to Gateway of Tally > Display > List of Accounts.
2. Click E : Export.
3. Select the Language.
4. Select the Format.
5. Enter the Export Location.
6. Enter the Output File Name.
7. Select the Type of Masters to be exported.
8. Set the option Include dependent masters? to Yes.
9. Enable Export Closing Balances as Opening, if required. The Export Report screen appears as shown below:
10. Press Enter to export.
The exported file is saved in the location specified.
'Exporting Masters' has been shared with
