https://help.tallysolutions.com/docs/te9rel53/Tax_International/Kenya_VAT/KenStock_Group.htm
Stock Group (Kenya)
To create a stock group
1.     Go to Gateway of Tally > Inventory Info. > Stock Groups > Create.
2.     Enter the Name of the stock group.
3.     Select the required group from Under.
4.     Enable the option Set/Alter VAT Details, if required.
5.     Press Enter to save the Stock Group Creation screen.
