https://help.tallysolutions.com/docs/te9rel53/Release_5_3_4/Product_Improvements.htm
Release 5.3.4 - Product Improvements
Inventory Reports
●      The value of Inwards and Outwards is displayed correctly in the Stock Summary report when viewed for a period, subsequent to the date of entry of physical stock voucher.
Excise
●      Error message about missing manufacturing date for the item was displayed when the Accept As is option was used for transactions recorded for items without a specified manufacturing date, resolved: Now, error message is not displayed when the Accept As Is is used for transactions that have items without a specified manufacturing date.
Service Tax
●      Swachh Bharat Cess is supported in Form ST3 report. This report can be printed as MS Word document and exported to XML format, as per the latest Form ST-3 template and XML schema.
TDS/TCS
●      e-TDS and e-TCS file formats support the latest file validation utility version 5.0: Form 26Q and Form 27Q e-returns can be exported in the format compatible with latest validation utility tool version 5.0.
VAT
Haryana
●      e-VAT annexures for Haryana VAT are generated as per the utility version 0.3.1.
Rajasthan
●      The latest e-VAT template of Form VAT 10 is supported.
*States covered for enhanced VAT experience
