The Job Costing feature in Tally.ERP 9 is used to track all the incomes and expenses for a project. Each project or job is created as a Cost Centre. The Cost Centres and Inventory Options (Maintain multiple Godowns) are integrated in Tally.ERP 9 to enable Job Costing, if the company maintains Accounts with Inventory features. For companies that maintain Accounts Only, the Job Costing feature will not be available.
Go to Gateway of Tally > F11: Company Features ( F1: Accounting features)
1. Set the options Maintain cost centres and Use cost centre for job costing to Yes.
2. Set Maintain multiple Godowns to Yes in F11: Company Features (F2: Inventory Features).
3. Click Accept to save.
Note: For companies, that have enabled the option Maintain accounts only, the Job Costing feature will not be available.
'Enabling Job Costing' has been shared with
