https://help.tallysolutions.com/docs/te9rel53/Data_Management/DM_Restore_Backup.htm
Restoring Backup
The Restore functionality allows you to restore the data backup of multiple companies, taken earlier. The backup of the companies is stored in a single file, named TABK.900, in the path defined by the user while creating backup. While restoring the backup data, Tally.ERP 9 displays the backup version followed by the last update time.
Before you take a data backup, ensure that you:
●      Do not restore very old or irrelevant data.
●      Do not restore data from damaged media.
●      Do not restore data in the same folder as the existing data, since it may overwrite the existing data.
To restore the data backup
1.     Go to Gateway of Tally > F3: Cmp Info > Restore to view the Restore Companies screen.
2.     Enter the Destination path - the location where data backup is to be restored.
3.     Enter the Source path, where data backup files of multiple companies are stored.
Note: The path specified can be on the same storage device, on an external storage device, or on a storage device on the network.
4.     Select the required companies in BackUp or Auto Backup, as shown below:
5.     Press Ctrl+A to restore the data backup.
See also:
Taking Data Backup.
