https://help.tallysolutions.com/docs/te9rel53/Tax_International/Kenya_VAT/party_ledger.htm
Party Ledger
On this page:
Creating a Supplier Ledger
Creating a Customer Ledger
To create a supplier ledger
1.     Go to Gateway of Tally > Accounts Info. > Ledgers > Create.
2.     Enter the Name of the supplier ledger.
3.     Select Sundry Creditors from the List of Groups, in the Under field.
4.     Set Maintain balances bill-by-bill to Yes.
5.     Enter the Default Credit Period, if any.
6.     Set Check for credit days during voucher entry to Yes, if required.
7.     Enter the Mailing Details.
8.     Select the required Country.
9.     Provide bank details, if required.
10.  Enter the PIN.
11.  Enable the option Set/Alter VAT Details and provide the relevant details.
12.  Press Enter to save.
To create a customer ledger
2.     Enter the Name of the customer ledger.
3.     Select Sundry Debtors from the List of Groups, in the Under field.
10.  Enter the PIN.
