https://help.tallysolutions.com/docs/te9rel53/Data_Management/DM_Split_Cmp_Data.htm
Splitting Company Data
Tally.ERP 9 allows you to split company data on the basis of the financial year.
Splitting company data has the following benefits:
●      It reduces the data size.
●      It improves the performance of Tally.
●      It secures data from the previous financial years in separate folders. You can work independently on the current financial year.
Prerequisites for splitting company data
Before splitting the data, the user must ensure that:
●      Backup of the data exists.
●      All unadjusted forex gains/losses have been fully adjusted by journal entries.
●      No purchase/sales bills are due. Check the Profit & Loss A/c and inventory statements (purchase/sales bills pending). You have to account them in the respective party accounts or in the bills pending account.
●      The company data is verified to ensure that no errors occur during splitting.
To split the company data
1.     Go to Gateway of Tally > F3: Cmp Info. > Split Company Data > Select Company.
2.     Select the required company from the List of Companies.
3.     Enter the required date in the Split from field.
The Split Company screen appears as shown below:
4.     Press Enter to split the company data.
Splitting company data - Important points
●      The Split from date is based on the existing data, and is considered as the beginning of the current financial year.
●      Once the company data is split, two separate companies will be created and opened, without any changes to the original data.
●      After the split, all the companies act as separate companies. Data can be entered, displayed, and altered in these companies.
●      The user can alter the names of the freshly created companies, if required.
