https://help.tallysolutions.com/docs/te9rel53/Tax_India/Excise_Mfg/Saving_ER1.htm
Re-Computing and Saving the Returns Form ER 1 (Excise for Manufacturer)
Saving the ER 1 Return
In the Form ER 1 screen, once the Uncertain Transactions count becomes 0, the details captured in ER 1 return can be saved.
To save the details click F6: Save. The details will be saved.
If any transaction is modified/added after saving the return, the values can be recomputed. The recomputed information can either be:
  • Overwritten on the return saved earlier
Or
  • Saved as  Corrected Return
To save the changes made in the returns
  1. Generate Form ER 1 report for the period for which the return was saved (for example, if the return was saved for the period 1-Apr-2014 to 30-Apr-2014, then view the report for the same period).
  2. The message The return values might have been changed, press F5 to recompute will be displayed with a new section comprising details of:
  • Modified Masters
  • Modified Vouchers: This section displays the count of transactions which are Altered, Created and Deleted
  1. To include the changes made into the report and recalculate the values, click F5: Recompute
  2. Once the values are recomputed, the section displayed for modified masters and transactions will not appear
  3. The recomputed values can be overwritten or saved as corrected return
  • To overwrite the recomputed information in the existing return, click F6: Overwrite. The message Do you want to Overwrite the Existing Return will be displayed. Press Enter to accept and overwrite the data with modified details.
  • To save the recomputed valued as corrected return click F7: Corrected Return. The message Do you want to Save the Corrected Return will be displayed. Press Enter to accept and save the Corrected Return.
  1. The modified Form ER 1 will be displayed after it is overwritten with modified data or saved as corrected return.
