The transactions entered in Tally.ERP 9 are immediately posted to the respective ledgers, books and registers. The inventory reports are generated based on these transactions. This facilitates instant reporting and faster decision making.
The appearance of reports can be changed according to your requirements. For example, you can generate comparison reports between different companies, periods of the financial year, and so on.
From a report, you can drill down to the next level of details by highlighting the item and pressing Enter. You can keep drilling down until you reach an individual voucher. Similarly, you can move back to higher levels by pressing [Esc] key.
The special features available for the currently displayed report are indicated on the button bar. You can activate these features with a single click. You can modify and print reports according to your requirements.
More:
'Display Inventory Reports and Statements' has been shared with
