https://help.tallysolutions.com/docs/te9rel53/Advanced_Features/Advanced_Accounting_Features/Use_Multiple_Addresses_for_Ledger_Account.htm
Using Multiple Addresses for Ledger Accounts
To create multiple addresses for a single ledger:
  • Go to Gateway of Tally > Accounts Info > Ledgers > Create.
  • The Ledger Creation screen appears.
  • Click F12: Configure button or press F12.
  • The Master Configuration screen appears.
  • Under Ledger Configuration, set the option Use MULTIPLE Addresses to Yes, as shown:
  • Save the settings.
Note: The option Use Multiple Addresses can also be enabled from Gateway of Tally > F12: Configure > Accts / Inventory Info.
  • Type the name of the Party in the Name field (E.g. Supplier A).
  • Select the group from the list of groups (E.g. Sundry Creditors).
  • Set / Fill the other required fields.
  • Set the option Set/Alter Multiple Mailing Details to Yes.
  • Press Enter.
  • The Address Type screen for the ledger being created appears.
  • Type the name of the Party’s Location (E.g. Supplier A WH-1).
  • Press Enter.
  • The Mailing Details screen appears.
  • Enter the Mailing Name, Address, State, PIN Code, and the Statutory & Taxation Information in the respective fields provided.
The filled Mailing Details screen appears as shown:
  • Press Enter, the Address Type screen appears.
  • Similarly, type another Address Type name to create the required Mailing Details.
  • Press Enter, the Ledger Creation screen appears.
  • Type the other required details and Save the ledger.
Use Multiple Addresses in Voucher / Invoice Entries
To opt for the required address type while passing transactions, follow the steps shown:
Example: Purchase Invoice.
  • Go to Gateway of Tally > Accounting Vouchers > F9 (F9:Purchase)
  • The Accounting Voucher Creation screen appears.
  • Select the required Date, type the Supplier Invoice No. and Date.
  • Under Party A/c Name, select the Party (Supplier A) and press Enter.
  • The Supplier Details screen appears, displaying the Primary mailing details.
  • In the Address Type field of Consignee, select the required address type of the Company (E.g. Branch Office) as shown:
  •  Press Enter.
  • In the Address type field of Supplier, select the required address type of the Supplier (E.g. SupplierA-WH-1) as shown:
  • Press Enter.
Note: The Consignee details appear only when you have enabled the option Allow Separate Buyer and Consignee Names in F12: Configure.
  • Complete the transaction and Save the invoice.
Note: Similarly, you can select the Customer ledger and choose the required Address Type in the Sales Invoice and other required voucher types.
