The count of all included, excluded, and uncertain transactions is displayed here.
Press Enter to display the Statistics of Vouchers.
Press Enter on Included Transactions.
The Summary of Included Vouchers appears as shown below:
You can drill down to the voucher level to make modifications, or exclude vouchers from this report.
Press Enter on Excluded Vouchers.
The Summary of Excluded Vouchers appears as shown below:
You can drill down to the voucher level from this report.
Press Enter on Uncertain transactions to drill down to the Summary of Exceptions.
Transactions with exceptions can be resolved from this report, and included to form a part of 26Q generation.
Unable to determine the TDS applicability for ledger/ stock item
The expense/purchase ledger that has been debited in a transaction, has not been enabled for TDS. Also, the expense ledger has not been tagged to a specific expense category for TDS.
Solution
This exception can be resolved by selecting a nature of payment.
To set the nature of payment
Press Spacebar to select a group.
Click N: Nature of Payment.
Select a TDS Nature of Payment.
The exception is now resolved.
Unable to determine deductee type for party
Reason
The deductee type of the party ledger is set to undefined.
Solution
Selecting a deductee type will resolve this exception.
To set the deductee type
Press Enter on Unable to determine deductee type for party.
Press Spacebar to select the Name of the Ledger.
Click D: Deductee Type.
Select the required deductee type.
The exception will be resolved.
PAN not available for the party
Reason
The party ledger selected has been enabled for TDS but PAN has not been specified
Solution
The PAN, and the applicability of PAN or the status of PAN application have to be recorded for the party.
To enter PAN Details
Press Enter on PAN not available for the Party.
Enter the PAN of the party and applicability, if PAN is available.
or
Press Enter in the PAN No field to go to the field PAN Status.
Select the PAN Status as applicable.
Notification not available for zero/lower rate of TDS
Reason
A lower rate or zero rate deduction is recorded for a transaction, and the corresponding notification number is not defined for the party/expense ledger.
Solution
This exception can be resolved by specifying the notification details.
In the drill down report for this exception, party ledgers that have been used to pass the zero rate/lower rate TDS entries will be listed. Identify the parties for which lower deduction/zero rate is applicable, select the relevant TDS Category, and provide the exemption notification number, applicability period, and the rate.
Unable to determine TDS applicability for ledgers
Reason
The TDS duty ledger has not been classified under a TDS Category.
Solution
Selecting a specific TDS Nature of Payment of TDS duty ledger will resolve this exception.
To select the Nature of Payment
Press Enter on Unable to determine TDS applicability of ledgers.
Select the Default Nature of Goods.
Duty ledgers for which TDS Nature of Goods has not been defined will be listed. Place the cursor on the required items and press Spacebar to select them.
Click N: Nature of Goods to set their Nature of Payments.
Unable to determine the tax rate for nature of payment
Reason
The tax rate for the nature of payment has not been specified.
Solution
Press Enter on Unable to Determine the Tax Rate for Nature of Payment.
Select Yes in the column Is Zero Rated, if required. Else, specify the rate of duty in the column Rate.
Press Enter.
The exception is solved.
Unable to determine the nature of payment in transaction
Reason
The nature of payment in transaction has not been specified.
Solution
To select the nature of payment
Press Enter on Unable to determine the nature of payment in transaction.
Select the required transaction, press Enter.
Select the nature of payment, or create the required nature of payment.
Press Enter.
Press Ctrl+A to accept the screen.
No link is available with booking and booking with deduction entries
Reason
The TDS category set for the purchase/expense ledger is not the same as the TDS category selected during voucher entry.
Solution
Setting the appropriate nature of payment will resolve this exception.
To resolve the exception
Press Enter on No link is available with collection voucher.
Select the transaction and click F3: Link All.
Note: If the TDS Category for the ledger is set to Any and a TDS Category is specified during voucher entry, this exception will not arise.
Unable to determine deductee details in cash transactions
Reason
In transactions that Cash has been selected in the field Party's A/C name, there are no deductee details available.
Solution
Selecting the appropriate party ledger will resolve this exception.
To select the party ledger
Press Enter on Unable to determine deductee details in cash transactions
Enter the Party Name or click M: Party List to select a party ledger.
Select the Deductee Type and enter PAN, if the details are not available in the ledger master.
Press Enter.
Press Enter to accept the details.
TDS deducted but not linked with expense/purchase transaction
This exception occurs when:
The deduction entry has not been linked to a booking entry.
Press Enter on TDS deducted but not linked with expense/purchase transaction.
Press Enter on the required entry.
Press spacebar to select the required booking vouchers.
Click F3: Autofill or F4: Full or F5: Partial, as required to enter the amount in Link to Deduction.
Press Enter.
Advance payment is done via third party.
Click F4: Direct Mapping.
Select Advance Payment.
Expenses/purchase returns not linked with expense/purchase transaction
Press Enter on TDS deducted but not linked with expense/purchase trasnaction.
Press Enter.
The payment is made to the government via third party.
Press Enter on Expenses/purchase returns not linked with expense/purchase transaction.
Select Tax Payment.
Transactions accepted with conflicts
Reason
The transactions recorded have conflicts or mismatches.
Solution
To resolve this conflict
Press Enter on the entry which has conflicts.
Press spacebar on the entry.
Click A: Accept as is.
Press Enter to accept the voucher as is.
This exception will be resolved.
The tax deduction details are grouped in the following heads:
Deduction at Normal Rate
Deduction at Higher Rate
Lower Rated Taxable Expense
Under Exemption limit
Exempt in lieu of PAN available
Press Enter on the required deduction type to view a detailed report.
All payment vouchers that have been ‘included’ for generating returns, will be captured in this section based on the category of payment.
Drill down to view the Payment Voucher report, where the date, voucher number, duty type (education cess, secondary education cess, etc.) and the respective amount, payment type (Interest, Late Fee, etc.) and the respective amount, and the total amount paid.
Press Enter to view the payment vouchers report.
The following details will be displayed:
Party Name
Deductee Type
PAN
Rate
Assessable Value
Income Tax
Surcharge
Education Cess
Secondary Education Cess
Total amount paid
'Statistics of Vouchers (TDS)' has been shared with
