Like provident fund, ESI amounts are calculated separately. However, you need to pay the amount using a single payment voucher.
To process the Employer ESI Contribution
Go to Gateway of Tally > Payroll Vouchers > Ctrl + F4: Payroll.
Press F2 to change the Voucher Date.
Click A: Payroll Auto Fill.
Select the required process in Process for field.
Enter the From and To date.
Select the appropriate Employee Category.
Select the Employee/Group from the List of Employees/Group.
Payroll Ledger from the List
of Ledger Accounts.
Press Enter
to go to Payroll Voucher Creation screen.
Press Enter to save.
'Processing Employer ESI Contribution (Payroll)' has been shared with
