To create journal voucher for CST adjustment
2. Click J: Stat Adjustment to enable required options in Stat Adjustment Details screen.
In the Stat Adjustment Details screen,
o Select the option Decrease of Input Tax in the Nature of adjustment field.
o Press Enter to save and return to voucher screen.
3. Debit the CST ledger created under the group Duties & Taxes.
o Enter the Rate, Assessable Value and Schedule Serial No., and select the Schedule Name in the VAT Details screen.
4. Enter the amount in Debit column.
5. Credit the input VAT ledger.
6. Press Enter to save.
'Decrease in Input Tax (Rajasthan)' has been shared with
