https://help.tallysolutions.com/docs/te9rel53/Tax_India/VAT/Kerala/KE_VAT_Class.htm
Creating VAT Classifications (Kerala)
To create a user defined classification
1.     Enable the option to define tax and commodity details in masters.
2.     Go to Gateway of Tally > Accounts Info. > Statutory Info. > VAT Classifications > Create.
3.     Enter the Name of the new classification.
4.     Enter the applicability date with the corresponding tax rates in Applicable From and Tax Rate columns.
The Stat Classification Creation screen appears as shown below:
5.     Press Enter to save.
To define Nature of Transaction in the Stat Classification Creation screen
1.     Click F12: Configure.
2.     Set the options Enable nature of transaction? and Provide commodity details? to Yes.
3.     Press Ctrl+A to save and return to the Stat Classification Creation screen.
4.     Select the required Nature of Transaction.
5.     Enter the Commodity Name and Commodity Code.
The Stat Classification screen appears as shown below:
6.     Press Enter to save.
