https://help.tallysolutions.com/docs/te9rel53/Tax_India/VAT/Haryana/Tax_on_URD_purchase.htm
Recording Tax on URD Purchase (Haryana)
To record journal entry to account tax on URD Purchase
1.     Go to Gateway of Tally > Accounting Vouchers > F7: Journal.
2.     Click J: Stat Adjustment.
o      Select the option VAT in the field Type of duty/tax.
o      Select the option Tax on URD Purchase in the field Nature of adjustment.
o      Select Additional Details for the type of adjustment selected.
3.     Press Enter to return to voucher.
4.     Debit a VAT ledger and enter the Rate, Surcharge Rate and Assessable Value in the VAT Details screen.
5.     Debit a surcharge ledger and enter the rate and assessable value in the VAT Details screen.
6.     Credit a ledger created under Current Assets, and enter the value in the Amount field.  The completed screen appears as shown below:
7.     Press Enter to save.
