To create a stock group
Go to Gateway of Tally > Inventory Info. > Stock Groups > Create
Enter the Name of the stock group.
Select the required group from the List of Groups.
Enable the option Should quantities of items be added, if required.
Enable the option Set/Alter excise details.
The completed Stock Group Creation screen appears as shown below:
Press Enter.
Click a link below to configure the expense/income ledger:
Configuring Selection of Tariff Type
'Creating Stock Group (Excise for Manufacturer)' has been shared with
