https://help.tallysolutions.com/docs/te9rel53/Data_Management/DM_Export_Data.htm
Export of Data
Data is exported from Tally for a variety of reasons such as for use in a third-party application, for filing returns, and so on. In Tally.ERP 9, data can be exported to seven formats, that is, ASCII (Comma delimited), Excel (Spreadsheet), HTML (web-publishing), JPEG (Image), PDF (Portable Document Format), XML (data interchange), SDF (using SDF utility).
Before exporting data in Tally.ERP 9, ensure that F11: Features of both the companies are the same.
To export the data
1.     Go to Gateway of Tally > Display > List of Accounts.
2.     Click E: Export to open the Export Report.
3.     Press Backspace to configure the export options.
o      Select Default (All Languages) as the Language.
o      Select the Format, as required.
o      Enter the Export Location, as required.
o      Enter the Output File Name.
o      Press Ctrl+A to accept.
4.     Press Enter to export.
See also:
Import of data
Exporting Masters
