https://help.tallysolutions.com/docs/te9rel53/Banking/Post-dated_Transactions.htm
Post-dated Transactions
Drill down from one of the months in the Particulars column. The Post-dated Transactions report appears as shown:
The report displays information as follows:
  • Date: This column displays the date provided in the voucher while recording the post-dated transaction in Tally.ERP 9.
  • Type: This column will indicate if a post-dated cheque has been issued or received.
  • Bank: This column displays the bank ledger that has been used to record the transaction.
  • Particulars: This column displays the name of the party ledger that has been used to record the transaction.
  • Inst. No.: This column displays the instrument number entered in the Bank Allocations screen while recording the transaction.
  • Inst. Date: This column displays the instrument date entered in the Bank Allocations screen while recording the transaction. That is, the date provided on the face of the cheque.
  • Status: This column indicates if the current status of the cheque. There are two types of status for a cheque:
  • Regularized, if the date of the cheque is equal or more than the Date of Last Entry indicated in the Gateway of Tally.
  • Pending, when the cheque date is lesser than the Date of Last Entry.
  • Amount: This column displays the value of the post-dated cheque issued/received.
Button options available in the reports
