The General Printing Configuration will help you to setup the print screens for various reports and transactions.
This Configuration is applicable to all the reports that are printed from Tally.ERP 9.
In Printing General Configuration, by default the following configurations are available
Setting this option to Yes, Tally.ERP 9 prints system date and time on Report printout. After enabling this option, (Print on all pages of report) sub-option gets displayed. This sub-option is used to decide whether to print system date and time in all pages or in first page only.
Setting this option to Yes, Tally.ERP 9 prints system date and time on Voucher printing. After enabling this option, (Print on all pages of voucher) sub-option gets displayed. This sub-option is used to decide whether to print system date and time in all pages or in first page only.
Setting this option to Yes, Tally.ERP 9 prints country, state and pin code with address of company in Reports and vouchers printing.
Note: This option also effect in invoice Entry. During Invoice Entry, Party’s country, state and pincode is captured in supplementary details below the address line.
Setting this option to Yes, Tally.ERP 9 will not print the vertical lines for reports and voucher printing. This enables faster printing in dot matrix printers.
This option is used to set top margin for reports and voucher printing.
Tally.ERP 9 prints in two formats – Neat and Quick. Neat printing takes advantage of fonts of the printer and is the default. It also compresses long data like long names and amounts and auto-fits them according to space.
Quick printing is suitable for Dot Matrix printers where speed is an issue. Hence, quick printing does not print fancy fonts. The auto-fit facility is, thus, not possible in quick printing.
Therefore, it will truncate data longer than the allotted space. To prevent this, Tally.ERP 9 provides two options:
This option enables to split long names into multiple lines during printing.
This option enables to split long amounts or numbers into multiple lines during printing.
This option enables you to print the Party Name and Address from left margin in invoice during printing
'General Printing Configuration' has been shared with
