https://help.tallysolutions.com/docs/te9rel61/Tax_India/gst/managing_hsn_code_sac_and_tax_rates.htm
Managing HSN Codes/SAC and Tax Rates
You can specify HSN code/SAC details and tax rates at different levels for the goods or services provided by your business. This is a flexibility provided for ease of use to accommodate your business needs.
It is recommended that HSN code/SAC and tax rate should be specified at the same level. In case you have specified these at different levels, you can remove it.
To know more about managing HSN/SAC, watch the following video:
Order in which HSN code and tax rate are applied for goods
Specifying HSN code and tax rate
Based on your business requirements, you can provide HSN codes and tax rates at different levels.
Business Requirement
Definition At
Most of the goods have the same HSN code and tax rate
Company
A group of items have the same HSN code and tax rate
Stock group
A few items have different HSN codes and tax rates
Stock item
Want to apply the same HSN code and tax rate for different transaction types
Sales/purchase ledger group
Want to segregate sales or purchase of items with the same HSN code and tax rate
Change the tax rate (not HSN code) during transaction
Transaction
After defining a tax rate at the company level, if a group of items attracts another rate, specify at the stock group level. For the items in the group, the rate specified at the group level is applicable. After specifying tax rates at the stock group level, if a few items in the group attract a different rate (or the rate set at the company level), override using rate setup at the stock item level. For the items, the rates specified at the stock item level are applicable.
You can specify tax rates at the sales or purchase ledger level, or at the ledger group level. This helps in situations where a special tracking as per the nature of tax is required. Then the rate defined at the ledger level will override the tax rates set at the company, stock group, or stock item levels.
Note: For ease of maintenance and appropriate use of tax rates, specify the rates at the level where you mark the goods as taxable.
A similar order is applicable in the case of HSN codes.
In case you need to specify a separate tax rate for an item in a specific transaction, you can do so, and the rate specified during the transaction will get the highest priority.
Order in which SAC and tax rate are applied for services
Specifying SAC and tax rate
Based on your business requirements, you can provide SAC and tax rate at different levels.
Tax Rate Definition At
Most of the services have the same SAC and tax rate
Company
A group of services have the same SAC and tax rate
Service ledger
Want to apply the same SAC and tax rate for different transaction types
Want to segregate sales or purchase of services with the same SAC and tax rate
Change the tax rate (not SAC) during transaction
Transaction
After defining a tax rate at the company level, if a few services attract a different rate, specify the rate in the service ledger. For the services, the rates specified at the service ledger level are applicable.
You can specify tax rates at the sales or purchase ledger level, or at the ledger group level. This helps in situations where a special tracking as per the nature of tax is required. Then the rate defined at the ledger level will override the tax rates set at the company level or at the service ledger level.
Note: For ease of maintenance and appropriate use of tax rates, specify the rates at the level where you mark the service as taxable.
A similar order is applicable in the case of SAC.
In case you need to specify a separate tax rate for a service in a specific transaction, you can do so, and the rate given during the transaction will get the highest priority.
