https://help.tallysolutions.com/docs/te9rel61/Creating_Masters/Inventory_Info/Altering_a_Units_of_Measure.htm
Altering Units of Measure
You can alter the units of measurement created in Tally.ERP 9.
To alter Units of measurement
1.    Go to Gateway of Tally > Inventory Info. > Units of Measure > Alter.
2.    Select the Name of Unit you want to alter from the Units list. The Unit Alteration screen appears as shown below:
3.    Make the necessary changes.
4.    Press Ctrl+A to accept.
You can delete a unit of measure by pressing Alt+D. However, a unit of measure that is part of a compound measure cannot be deleted without deleting the compound measure first.
